TLSR8366发射功率测试问题
2.4Ghz proprietary mode related discussions
Post Reply
LINP_Lan
Sat Jun 03, 2017 2:59 pm
Hi,
您好,我们最近是用贵司的TLSR8366以及TLSR8368做了一套灯控系统,最近我们的产品要送到FCC过认证,于是自测了TLSR8366的发射功率,结果如下:
程序设置发射功率 实测发射功率
RF_POWER_OFF -61.67dBm
RF_POWER_m32dBm -40.96dBm
RF_POWER_m20dBm -38.52dBm
RF_POWER_0dBm -42.09dBm
RF_POWER_4dBm -39.79dBm
RF_POWER_8dBm -38.76dBm
结果与程序上设置偏差较大!(详细测试过程及结果见附件文档)
请问:
1、 我们测试的方法或者程序上配置是否有误,导致测试结果不对?
2、 贵司实际结果是否有这么大的偏差?
3、 如何改进8366发射功率呢?
TLSR8366发射功率测试问题.pdf
TLSR8366发射功率测试问题
(1.21 MiB) Downloaded 368 times
TL_Zhenfei
Contact:
Thu Jun 08, 2017 3:34 pm
Try to use attachment to verify the hardware connection is good.
After power on default :in carry mode ,at 2430MHz frequency ,the Txpower is 8dbm .
8366_emi.zip
(2.36 KiB) Downloaded 241 times
LINP_Lan
Sat Jun 10, 2017 10:41 am
TL_Zhenfei wrote:Try to use attachment to verify the hardware connection is good.
8366_emi.zip
您好,我试过您的程序了。
一共试过两块8366开发板,一块我们自己设计的硬件。
结果如图,测试的结果是2646M -54dBm:
[img]
[/img]
TL_Zhenfei
Contact:
Fri Jun 23, 2017 3:20 pm
Usually in testing TXpower, the setting of instrumentation is REF = 20 DBM, Span = 50 MHZ, RBW = 5 MHZ. other settings instrumentation can be automatically set. You may need to check again 2402 MHZ frequency spectrum instrument Settings.
Post Reply
