SWS for debug text? (8266)
Discussions on BLE related products, including standard BLE devices, BLE mesh, and Apple HomeKit products
Post Reply
wecango
Sun Jul 14, 2019 5:22 pm
Is it possible to use the SWS connection with EVK + Swire for debug text output?
I see swire_putc() in the SDK and commands like tcdb uart l -s 4
Can these work together to allow debug print statements to work via SWS?
If so, are there any examples or documentation on how to make this work?
Many thanks.
TL_bloom5
Mon Jul 15, 2019 6:07 pm
hi wecango,
With swire_putc you will need a extra PC tool to pick up the text log, and the PC tool is not available for now. I would recommend you to use gpio simulate uart tx, which you could find an example in the 8258 SDK feature_test build file app_config.h, with UART_PRINT_DEBUG_ENABLE enabled you can output text log via gpio and use a serial tool to pick up the text log.
Post Reply
